Hi everyone,
I was hoping you could assist me shortly with understanding the relationship between standard flow simulators such as Olga / Ledaflow, virtual flow metering and physical MPFM's - does Olga need a physical MPFM to collect data for it? if not - what is the difference between a Virtual Flow Meter and Olga?
I know these are very basic questions (probably ill constructed) but i would appriciate any help in understanding the different roles and features of the three.
Thanks,
Gur
Olga / Ledaflow Vs. Virtual Flow Metering And The Need For Mpfm's
Started by gharell, Jan 21 2013 06:02 AM
measuring flow rategas flow oil process engineering gas flow metering multyphase flow virtual flow metering flow assurance flow simulators
No replies to this topic
Posted 21 January 2013 - 06:02 AM
Flow Through A Perforated PlateStarted by Guest_Ahmadhamzahperta_* , 13 Feb 2026 |
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
