Dears,
I'm dealing with pipeline in AspenPlus.
I want to calculata the outlet pressure form a 3000m long pipeline.
Inlet T = 200°C, P=300bar.
Fluid = mixture of water+co2 (0.99, 0.01 of mass)
pipe diameter =0.25m
adiabatic.
When running the software, the result is an error:
** ERROR
FLASH CALCULATIONS FAILED TO CONVERGE IN 30 ITERATIONS. PROBLEM IN
FLASH CALCULATIONS FOR PROPERTIES.
** ERROR
BECAUSE OF ERRORS ENCOUNTERED DURING THE CALCULATIONS
FOR SEGMENT 1, PIPELINE CALCULATIONS CANNOT PROCEED.
ERROR CODE = 4
Do you know how to solve the problem?
Best Regards
Roberto
