Edited by wynnl, 26 March 2013 - 09:21 PM.
Posted 26 March 2013 - 08:25 PM
Posted 25 April 2013 - 02:36 AM
Hi wynnl,
The total entropy change is zero because entropy chnage of steady flow devices such a compressors, nozzles, pumps and heat exchangers is zero during steady state operation.
Since electric motor is example of closed system
ΔE = Q - W ( ΔE = 0 for closed system)
Q = W
http://en.wikipedia....Internal_energy
http://lorien.ncl.ac...vers/isothe.htm
http://www.tim-thomp...opy2.html#2lotc
http://en.wikipedia.org/wiki/Entropy
http://www.entropyla...ropyenergy.html
You have current (I) and voltage (V) given, so you should find power(P=VI) which will be electrical work (Welec) done ( which will be negative).You have been given mechanical energy which is shaft work done (Wshaft).You have temperature (T) and total work done by electrical and shaft.(Welec + Wshaft).
Now put this all data in you entropy balance equation which you know and find rate of entropy generation (Sgen).
ΔS = Σ Q/T + Sgen
Where
ΔS = 0
Q = Welec + Wshaft
Entropy as a thermodynamic property has its origin in the second law of thermodynamics.
I hope it helps.
Shivshankar
Edited by Shivshankar, 02 May 2013 - 07:07 AM.
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
Energy Analysis In Aspen Plus 14.2Started by Guest_Sarishma_* , 23 Mar 2026 |
Aspen Plus Rcstr Convergence Issue – Mass Balance Error In Anaerobic DStarted by Guest_Marie26_* , 05 Apr 2026 |
Basic Chemistry - Dosage Of Sodium HypochloriteStarted by Guest_Dorota86_* , 05 Apr 2025 |
