Correlation For Pressure Drop In Flarenet & Liquid Amount Predicti
#1 silkroute
silkroute
  • 12 posts
Posted 19 April 2013 - 02:57 AM
Dear members,
Kindly help me on following topics;
1) What correlation is mostly accepted in industry for pressure drop/flow regime prediction in Flarenet ? Beggs & brill or teital-dukler.
2) How can i calculate amount of liquid arriving to flare KO drum due to JT effect in downstream of PSV / Blow Down valve?
Appreciate your valuable input.
Thank you.
Silkroute....
#2 flarenuf
flarenuf
  • 104 posts
Posted 19 April 2013 - 10:35 AM
Silkroute
There is no such thing as " mostly accepted in industry"  different companies use different equations
personally i always use B&B homog
You do not have to calculate the  liquid amount , FNT does it for you , look at the results and you will see lquid data there.
flarenuf
#3 silkroute
silkroute
  • 12 posts
Posted 19 April 2013 - 02:34 PM
Silkroute
flarenuf
flarenuf,
Thank you for your prompt response.
I have read somewhere that B&B gives most conservative result and also don't consider inclined line.
Could you please share your experience ?
Thanks in advance.
Silkroute....
#4 flarenuf
flarenuf
  • 104 posts
Posted 22 April 2013 - 09:21 AM
Beggs & Brill - The Beggs and Brill method is based on work done with an air-water mixture at many different conditions, and is
applicable for inclined flow.
Personally i still prefer the b&B homog for best all round results
Flarenuf
#5 silkroute
silkroute
  • 12 posts
Posted 28 April 2013 - 03:46 AM
flarenuf,
Thank you for your help.
