I'm a engineering student and I'm trying to understand how does a steam turbine work in a solar thermal power plant. Usually, in a vapor power cycle electric power generation is constant, because the turbine inlet parameters are always the same. But, in a solar power plant, water is boiled thanks to the sun energy (DNI) which varies during the day. So, the inlet temperature of the turbine will not stay constant. Thus, the electric power generation will also vary.
But I have no idea how to know the efficiency and the outlet parameters of the turbine depending on the inlet parameters. Do you know some websites which could explain it?
Thank you for your help.
