Dear all,
How can i calculate the overall heat transfer co-efficient of an insulated tank(CS+35 mm PUF Insulation) and could anyone explain me the relation of wind speed and heat transfer co-efficient.
Thanks in advance.
Arun
Posted 24 April 2013 - 09:50 PM
Dear all,
Thanks in advance.
Arun
Posted 24 April 2013 - 11:25 PM
http://www.cheresour...insulated-pipe/
You should use the search the function or refer to the link attacked.
Posted 26 April 2013 - 02:43 AM
Thank you sir.
But the above one is for pipeline and in my case it is a sphere. is it the same?
Arun
Posted 26 April 2013 - 02:59 AM
http://books.google.... sphere&f=false
Consider this resource to support , I did not pay attention enough about your query (sphere) . Google is your best friend for such problem !
Posted 26 April 2013 - 08:52 AM
Is your tank mixed or stagnant? If it is not mixed thoroughly then any heat transfer coefficient you calculate will be wrong.
There is an article on this site for heat transfer in agitated tanks with insulation.
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
Waste Heat BoilerStarted by Guest_Prim_* , 25 Apr 2026 |
