Hi
FF has the definition of the ratio of pressure at vena contracta (Pvc) to vapor pressure.
Could anybody explain how FF can be calculated using following expression?
FF=0.96-0.28*sqrt(Pv/Pc)
I don't know how Pc is related to this matter.
Thanks.
Posted 04 May 2013 - 12:13 AM
Hi
Thanks.
Posted 04 May 2013 - 12:14 AM
Sorry, i should say this topic is about control valve sizing. FF is used to calculate maximum flow rate through a control valve.
Posted 04 May 2013 - 05:53 AM
Calgary,
consider this resource ,it should help
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Minimum Distance Between Blowdown Valve And Cold Vent Outlet In A HighStarted by Guest_AMINEBELAL_* , 15 May 2026 |
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
