Absorption Tower
#1 mixednuts
mixednuts
  • 21 posts
Posted 09 May 2013 - 03:49 AM
my teacher tasked me with this problem and I have cracked my brains but to no avail. lets say u are given a spray absorption column. The aim of this absorption tower is to scrub SO2 from the exhaust gas by using washwater of 20% Na2SO4 in a counter current fashion. The exhaust gas will be flowing upwards while the washwater is being sprayed downwards in a conical fashion. How do I do the mass transfer/balance for this?
The information I have:
for the exhaust gas: Temperature, volumetric flow rate, mole% composition, density, mass flow rate.
for the washwater: the volumetric flow rate, density, mass flow rate, temperature and 20% Na2SO4.
I have searched the net for spray absorption column but all the calculations and methods are based on packed or tray columns. Can the kind souls in here guide me to a direction so that i can read up or at least have an understanding of the situation and the equations applicable to this situation
Thanks,
Mixednuts
#2 mixednuts
mixednuts
  • 21 posts
Posted 12 May 2013 - 07:05 PM
anyone able to help?
appreciate it
#3 thorium90
thorium90
  • 1,073 posts
Posted 14 May 2013 - 08:35 AM
You can read Coulson and Richardson Vol 6, Chapter 11.14.2 onwards.
You can also read Mass Transfer Operations by Robert Treybal
This spreadsheet will be helpful
http://www.cheresour...crubber-design/
Just because its a solution doesnt mean the equations used will be completely different.
Edited by thorium90, 14 May 2013 - 08:44 AM.
#4 breizh
  • 6,984 posts
Posted 14 May 2013 - 10:30 PM
Consider this resource to support .
To get a more effective support , please show us what you did .
