Pump Motor rating is 75 HP. As per pump curve @ head of 200 ft and 800 gpm the power consumption is 75 HP.
RV is to be sizing for the vessel at downstream of the pump with MAWP of 143 psig.
Normal suction pressure of pump is 5 psig.
During a certain operation the suction pressure at pump would be 120 psig and the relieving pressure at the downstream vessel due to blocked outlet is 157 psig. 37 psi differential head corresponds to 90 ft of head.
And as per extrapolated pump curve the flow at 90 ft head is 3500 gpm.
This is a typical runout situation for pump. I need to determine the relieving liquid flowrate.
I feel 800 gpm should be the the relieving rate but I am not able to convince myself.
Any help is highly appreciated..
