Hello
For one of my projects, I have to develop a monitoring tool for a 2 phase heat exchanger so as to see the effects of fouling over time (i.e if duty is decreasing, we know its time to clean up the exchangers). It is a shell and tube heat exchanger, with propane/propylene mixture on tube side and cooling water on shell side. The process vapours enter as superheated vapour, and exit as subcooled liquid. I have the composition of the inlet and outlet compositions, as well as inlet/exit temp of process and water. I also have inlet pressure for process stream. Can someone tell me how to go about doing this, as I am not sure how to find heat duty (accounting for phase change), and also with variable water/process flowrates/pressures.
thanks
