Dear:
Please tell me what will be happen when due to mulfuntion of firing control mulfunction the fuel increases too much but air remain constant?
Is there risk of explosion?
best regards
Posted 23 May 2013 - 11:33 PM
Dear:
best regards
Posted 24 May 2013 - 02:27 AM
It could be possible some amount if afterburning occurs. But a malfunction of firing control?
Posted 25 May 2013 - 12:31 AM
control valve of fuel suddenly fully opened and no more air be available for combustion.
this condition cause explosion or not
Posted 25 May 2013 - 08:57 AM
You should consider implementing safety interlocks and incorporate safe process designs.
It is already burning the fuel. But if your tubes contain high pressure steam or some high pressure flammables and ruptures due to the high temperatures, your boiler would surely explode.
Edited by thorium90, 25 May 2013 - 10:34 AM.
Posted 25 May 2013 - 09:22 PM
Standard boiler combustion controls work on "lead/lag mechanism" to avoid fuel rich mixture at any point in time during load increase or decrease. In case of load increase, air to be increase first, then followed by fuel (air to lead) and while load is to be reduced, fuel is decreased first and then air is decreased (air to lag).
Sudden opening of fuel without a proportionate match with air carries a risk of formation of explosive mixture inside the fire box, that could lead to explosions
Posted 25 May 2013 - 11:20 PM
Dear m.r.rahimzadeh
Good day!
Please consult :
For more specific details please share details of your boiler
Ahmed Attyub
Waste Heat BoilerStarted by Guest_Prim_* , 25 Apr 2026 |
Equal Load Sharing And Anti-Surge ControlStarted by Guest_panoska_* , 02 Nov 2025 |
Control Strategy For 2 Air Compressors In ParallelStarted by Guest_panoska_* , 31 Oct 2025 |
Real Or Ideal Cp/cv For Control Valve CalculationsStarted by Guest_sumwunrandom_* , 14 Oct 2025 |
Sizing And And Process Control Of Filter PressStarted by Guest_Amalina Jamil_* , 11 Mar 2019 |
