Vacuum Test On Heat Exchanger
#1 vusi
vusi
Posted 04 June 2013 - 02:17 AM
Hi
If a repair has been done on a vaccum operated heater,How do you do a hydrolic pressure test on vaccum? Please help.
Vusi
#2 hoangdieu
hoangdieu
Posted 10 June 2013 - 10:40 PM
1 place adhesive tape on all the flange connection, making sure that it is sealed to flange. Then make a small hole on the tape
2 admit condensate, from the lowest point and keep the vent on the highest point
3 stop the water injection when the condensate is coming out from the highest point
4 check systerm for the leak and attend them
5 when no more leaks are detected on the systerm , the test can be considered completed.
