I am designing an orbital railgun simulator in MS Excel that should be able to propel a 20kg projectile to about 1% SoL. This would give 250 kT of TnT equivalent ( about 1TJ ) at ground zero.
I have already completed a simulator for the railgun and only need help with the ballistics of the projectile.
What I have :
Final Velocity ( +- 300 000 m/s )
Projectile Shape ( rod like ; much like the discarding sabot rounds that tanks use )
Projectile weight ( 20kg )
Projectile density ( tungsten carbide )
Air density ( assuming incompressible flow )
Total distance that projectile has to travel ( 2000 km )
Railgun simulator ( Can achieve any exit velocity )
What i need :
Exit velocity needed of the projectile from the barrel to achieve 1% SoL at ground zero.
As far as I understand, the flow regime will be turbulent all the way, and this is were I am stuck. I do not have a value for the drag coefficient of my projectile, but I did find a few values, but they are not for a rod-like shape with a sharp point.
I think I only need a Cd value for my equation then ill be fine and a equation for its contact area.
I can attach the railgun simulator if anyone would want it but it is not needed to solve the problem, it merely supplies the initial velocity.
Thank you for your time!
