Water Vaporization Rate Problem
#1 Spliknot13
Spliknot13
  • 37 posts
Posted 18 June 2013 - 01:36 AM
I need help on solving this one. So the problem is Dry air is bubbled through 25.0 liters of water at a rate of 15 L(STP)/min. The air leaving the liquid is saturated with water at 25 C and 1.5 atm. How long will it take for all the water to vaporize? Err. So what I did was got the volume/min at 25C and 1.5 atm which is 10.915 L/min. I sort of just subtracted the concentrations of dry air and air saturated with water to get the mole of water/L then multiplied it by 10.915 which is 0.1822 mole water/min. I think 25L water is just approximately equivalent to 25000g/(0.1822x18) which is 127 hours which is wrong. Already thought of using the saturated pressure of water at 25 C but I dont know how to use it. Comments/ideas will be really helpful. By the way it says here in the book that the answer is 67.8 days.
#2 latexman
  • 1,904 posts
Posted 18 June 2013 - 08:25 AM
I wish you had attached your calcs.  That would have been faster for us.
Absolute saturation (absolute humidity) from Felder and Rousseau's Elementary Principals of Chemical Processes:
sa(ha)=pvMv/[(P-pv)Mdry air]          mass of vapor/mass of dry air
pv=p*(T) at saturation
p*(T)=vapor pressure of water
pv=partial pressure of water
Mv=molecular weight of water
Mdry air=molecular weight of dry air
I assumed the flow of air was 15 L/min of dry air and got 49 days.  Is air measured before or after the water?
Edited by latexman, 18 June 2013 - 06:51 PM.
#3 latexman
  • 1,904 posts
Posted 18 June 2013 - 08:48 AM
Found my error.  67.8 days!  It isn't pretty, but I attached my calcs.
Edited by latexman, 18 June 2013 - 10:14 AM.
#4 Spliknot13
Spliknot13
  • 37 posts
Posted 18 June 2013 - 06:56 PM
thanks a lot for the help. :)
