Why do we flare in the refinery, and what are the benefit of zero flaring interms of environmental benefit
Posted 23 July 2013 - 09:30 AM
Posted 24 July 2013 - 12:34 AM
Because we don't want:
To pollute the refinery environment with relieved HCs...and
To create an environment inside the refinery which would be ready to explode...!
Posted 24 July 2013 - 01:52 PM
Hi;
Fallah answer is the reason to install a flare in a refinery.
In the refinery you will normally produce HC with little to non economic value that in most cases is burnt in the flare, you will also occasionally send safety valve reliefs and other miscelaneous vent and in many refinery the flare system purge. The flare change the HC pollution into CO2, NOx etc with less environmental impact.
Zero flaring is an alternative to reduce all that emission by reducing the amount of HC that you burn. The main approaches are:
Recompress the combustible gases and use then as energy input to the refinery (fuel Gas)
Reduce Safety valve relief by installing instrumented safety system such as hipps etc that prevents the system to reach a point were PSV opens.
Hope i was of any help
Hugo
Posted 24 July 2013 - 02:53 PM
Goldenboy,
Read below links,
http://answers.yahoo...13200723AApJM9r
http://answers.yahoo...12034310AAFhpfa
http://answers.yahoo...04023742AAFK7oM
http://answers.yahoo...20141033AASRX6V
http://epa.ohio.gov/...gas flaring.pdf
http://www.exxonmobi...ing_flares.aspx
Hope this helps.
Shivshankar
Edited by Shivshankar, 24 July 2013 - 03:07 PM.
Posted 30 July 2013 - 09:42 AM
1. To completely eliminate flaring in refinery is not possible due to safety reason and environmentally.
2. However, to minimize flaring shall be the right things to do...since the flare must be lighted by pilot gas continuously..
Posted 31 July 2014 - 03:14 AM
Traditionally, flares are the final equipment used to ensure a plant's safety, excessive gases caused by process upsets and gas and/or oil wells are to be environmentally disposed. Such disposal is achieved by many ways: Gas reinjection, Incineration, power generation and direct venting to atmosphere. Some of these methods are preferred rather than others. Flaring is the most commonly-applied choice.
Flaring exceeded 12500 MMSCFD globally. That is why new technologies are used to recovered these gases for more economical uses rather than being waste.
Throughout flare gas recovery, we both achieved economic and environmental targets.
Regards.
Mohammad Helmy.
Egypt.
Posted 15 December 2014 - 08:36 AM
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Back Pressure Of Elevated Flare Vs Ground FlareStarted by Guest_Sid__* , 04 Jan 2024 |
Floating Closed Drain Drum With FlareStarted by Guest_Falah_* , 26 Jan 2024 |
Literature To Read For Refinery Oil MovementStarted by Guest_Noman97_* , 09 Nov 2023 |
Low Molecular Flaring (H2 Rich Flare Gas)Started by Guest_PKS_* , 23 Dec 2023 |
