hi friends
What's the formula used for an isentropic compression to calculate effeciency ?
T1= 327,59 K ; P1=618,4 Kpa ,Cp/Cv = 1,149
T2 = 379,05 K ;P2= 1825 Kpa , Cp/Cv = 1,195
Thanks a lot
Posted 30 January 2014 - 05:19 AM
hi friends
Thanks a lot
Posted 30 January 2014 - 07:27 AM
Isentropic efficiency is the ratio of the isentropic work to the actual work done by the compressor
Did you try google, where there are thousands of references available:
http://petrowiki.org/Compressors
Posted 30 January 2014 - 07:32 AM
Yes , I have used this article but the problem the ratio Cp/Cv isn't constant
Edited by N.BH, 30 January 2014 - 07:34 AM.
Posted 30 January 2014 - 07:43 AM
You can use the arithmetic mean of the two Cp/Cv values in your starting post.
Ankur
Posted 30 January 2014 - 07:56 AM
the hysys give me an adiabatic efficiency : 75% , then I used this value to predict how much should be the Cp/Cv ratio , I found 1,113 which is less than the initial Cp/Cv
Posted 30 January 2014 - 09:02 AM
I think it would be better to put similar questions in student section,
anyway you can solve as ideal gas or real gas,
for a ideal fluid you can calculate discharge temperature
for some predefined process (for example isentropic) as
t2 = tin*(pout/pin)(k-1)/k
k = cp/cv (average as suggested by Ankur)
then calculate Hin (Pin,Tin), Hout (Pout, Tout), H2 (pout,t2)
since you know cp it's easy,
finally, efficiency = (Hout-Hin)/(H2-Hin)
replace Hout-Hin and H2-Hin with
ideal gas formulation to obtain the direct correlation
for real fluids things are a bit more complex,
if it's a pure fluid you can replicate the procedure
getting the values from a chart (i.e. a Mollier chart
or Pressure-Enthalpy diagram where you can find H,S values)
this allows accurate results
for mixtures you would need some thermo package to calculate
H, S with a EOS or similar procedure,
I utilize Excel with Prode Properties for these calc's
but other simulators can give equivalent results.
Do not forget that before to use a simulator you need
to get a good knowledge of thermodynamics.
Heat Of Compression Air DryerStarted by Guest_ponnusj_* , 26 Oct 2023 |
Multi-Stage CompressionStarted by Guest_Mirzazada_* , 27 Sep 2021 |
Economical Tradeoff Of Gas Compression Pressure Vs Tank Size?Started by Guest_RonC74_* , 02 Mar 2021 |
Isentropic Efficiency Compressor And TurbineStarted by Guest_panoskagiou_* , 15 Feb 2020 |
Adiabatic Compression And Polytropic CompressionStarted by Guest_sahilchaudhary10_* , 26 Jul 2019 |
