I need some help in this:
How do I calculate the efficiency of this turbine (HPP-HP section)?
Thank you
Posted 31 January 2014 - 07:03 AM
Thank you
Posted 31 January 2014 - 01:04 PM
The basic definition of an expansion turbine efficiency is: (the actual work done by the turbine / the calculated work done by the turbine) (100) .
One can calculate the work expected out of the turbine….. BUT do you KNOW the actual work done by the turbine? If you do, you aren’t telling us.
Posted 31 January 2014 - 01:17 PM
Thanks for your reply and sorry for my poor english.
I don't know the work done by the turbine. My problem is exactly this.The information I posted here is just what I got to solve this problem.
Posted 31 January 2014 - 03:02 PM
You use steam properties, pressures, and temperatures to calculate efficiency of the HHP-HP section. A Mollier chart is most useful for this purpose.
Edited by Bobby Strain, 31 January 2014 - 03:03 PM.
Posted 31 January 2014 - 03:16 PM
In Mollier chart I will get the theoretical enthalpy, right? Where can I find the real enthalpy in this case?
Thanks,
Posted 31 January 2014 - 04:25 PM
Also from the h-s diagram (Mollier diagram). You know P1, T1, P2 and T2 so ....... piece of cake.
http://www.ohio.edu/.../Chapter6a.html
Edited by PingPong, 31 January 2014 - 04:32 PM.
Posted 31 January 2014 - 06:45 PM
Crack:
I hope that by now you've realized that there is no way you can know the REAL, ACTUAL enthalpy of the outlet enthalpy unless you're the manufacturer of the turbine and you've run exhaustive pilot tests with your turbine to discover the resulting efficiency when you operate your turbine.
How else, logically, could you ever know the efficiency of the turbine? Turbine efficiencies are not calculated with analytical equations; they are the result of the actual turbine's operation - and that depends on how good the manufacturer is at making turbines. Does that make horse sense?
Some turbines are more efficient than others.
Schultz Polytropic Efficiency CalculationsStarted by Guest_SickPuppy0_* , 27 Feb 2023 |
Murphree Efficiency From Temperature ProfilesStarted by Guest_lilbrain431_* , 18 Jan 2023 |
Steam Turbine Extraction And Letdown ValveStarted by Guest_zavtranguyen_* , 07 Oct 2022 |
Polyester Production Distillation EfficiencyStarted by Guest_Tolgahan_* , 01 Sep 2022 |
Gas Turbine Simulation, Part-Load OperationStarted by Guest_twana_* , 21 Jul 2022 |
