Hi all,
I have a case whereby the operating temperature of the discharge of the compressor is 180°C.
When I trip the compressor, the maximum temperature of the discharge of the compressor has reached 210°C which has exceeded the design temperature of the pipeline of 200°C.
However the temperature only exceeds the design temperature for a duration of 0.4s.
My question is are there any API or ASME standards out there which justifies that the pipeline is capable to absorb the short duration increase in temperature (similar to how incidental pressure can be 10% above the design pressure due to surge)?
Thank you in advanced
