Hey Guys
I am sizing a relief valve for a fire case.
At the relieving conditions (In my case 282 barg and 295 degC) all the Hydrocarbon contents of my system will be in the vapour phase. There is however still liquid water present (Critical P & T of water 373.9degC & 219 barg).
I have used the API equations for vessels filled with vapour / supercritical fluids however I am interested to understand the effects of the water in the system.
The relieving pressure is above the critical pressure of water (219 barg) so as the temperature increases above 373.9 degC the water will go from being a liquid to supercritical (dense phase). Would this change have a latent heat in which I could figure out the relief rate? ( Relief = heat input / latent heat). I'm presuming not as the change is not going through vapour phase?
HYSYS gets very confused when trying to pass a water stream at these conditions through a heater and setting the downstream vapour fraction to 1 in order to get the liquid / vapour mass enthalpies. It states that a temperature at specified conditions cannot be specified (presumably because its in dense phase and cannot figure it out).
Any advice would be much appreciated
