Hi Chem Enthusiast,
Your total 3 years of experience includes 1 year in pharma and 2 years in OTS.
Lets not consider 1 year of pharama exp here mainly due to following -
1. First job, generally a lot to take in during trainings and all.
2. you must have gained some useful experience on few unit operations (mostly batch) and possibly stream system or water treatment system.
OTS is a useful experience where you learn the whole process, esd logic, interlocks, DCS interface, control logis etc. however you miss on enormous amount of important process design stuff that you would, otherwise, learn during FEED, Detail Engg or Commissioning. OTS does not give you the opportunity to work on -
1. actual design issues may be various process design cases, equipment sizing
2. preparing equipment / instrument specifications for process equipment
3. understanding the sizing basis and performing calculations.
4. other brownfield issues related to flare system, materials, blowdown calc etc.
5. preparing process drawings such as pfds and p&ids
and many more
In my opinion, operations (working on site) is the best place to learn stuff. However not everyone can work on site / operatrions.
If you are keen on oil&gas industry, then EPC seems to be right choice where you are likely to gain various types of experience during next few years. Few FEED/detail design projects under your belt will help you learn a lot of stuff. It depends wjhat kind of projects this EPC executes. Are they more upstream or downstream projects? Onshore or Offshore? LNG, CNG, GTL projects? Are these more brownfield modifications or Greenfield projects?
I believe you learn better and quicker in a medium/small ish company or office than a very large group.
Good luck to you whatever you chose.
VK
Edited by Steady, 17 March 2014 - 10:36 AM.
