Hi
I have one query please.
We have a reactor with internal coil and outer jacket. Coil and jackets are used for cooling [with cooling water] and heating [using steam].
It is a batch process - and steps are:
1) add raw materials
2) Heat up to 125 deg C [use 3barg steam in coil and jacket both]
3) Exothermic reaction will bring temperature from 110 to 200 degC
4) Cool down batch from 200 to 125deg C [use cooling water in the jacket ONLY to avoid thermal sock to the coil]
5) Cool down batch from 125 to 40degC [use cooling water in a jacket + coil both]
Now if I keep coil outlet valve as air fail close, there would be two situation if my understanding is correct?
condition 1) Liquid expansion in the coil - batch is below 100deg C, coil is full of water and air fail close valve at coil outlet will cause trapped in water to expand.
condition 2) Vaporisation in the coil - batch is above 100deg C [let's say maximum 125deg C] , coil is full of water and air fail close valve at coil outlet will cause trapped in water to vaporise.
Coil is 3inch in diameter, has design pressure of 10barg and contains 400 litre water.
Query:
If I have condition 1, I have read that API 521 has guide which i can follow for sizing the relief valve
But if I have condition 2, am i right in saying that vapour release rate would be equal to that of heat input from batch to the coil trapped water? Also I do not know how to calculate the pressure exerted by the vapour [here water vapour] formed.
Any help from members? Thanks
Edited by kinetic123, 02 April 2014 - 05:29 PM.
