Hi
I have one query please.
We have a reactor with an internal coil and outer jacket. Coil and jackets are used for cooling [with cooling water] and heating [using steam].
It is a batch process - and steps are:
1) add raw materials
2) Heat up to 125 deg C [use 3barg steam in coil and jacket both]
3) Exothermic reaction will bring temperature from 125 to 200 degC
4) Cool down batch from 200 to 125deg C [use cooling water in the jacket ONLY to avoid thermal sock to the coil]
5) Cool down batch from 125 to 40degC [use cooling water in a jacket + coil both]
Please attached drawing for valves' air fail close/open positions as it stays at the moment.
As both valves all the valves on coil inlet and outlet are 'air fail close', there would be the situation of trapped fluid within the coil - below is my understanding.
condition 1) Liquid expansion in the coil - batch is below 100deg C, coil is full of water and air fail close valve at coil outlet will cause trapped in water to expand.
condition 2) Vaporisation in the coil - batch is above 100deg C [let's say maximum 125deg C] , coil is full of water and air fail close valve at coil outlet will cause trapped in water to vaporise.
My queries:
- Do you think Condition 2 would happen at all? If not, then why?
- Also, I believe, either of AV04 or AV05 should be air fail open as no pressure relief protection on coil especially, AV05?
Would appreciate input from members.
Edited by kinetic123, 04 April 2014 - 07:39 AM.
