Hello there,
The plant I am working in just had Turnaround. So I need to measure the performance of the plant and compare it with the performance before the turnaround. Since this is the first turnaround therefore no previous data is available.
Is the any way of measuring the plant performance such as calculating heat duty for the exchangers and compare it before turnaround. There are two extractive distillation column and two conventional. Are the any specific ways to prove the plant is better after the turnaround.
