Simulation W/proii: Methane Liquefaction Using Cascade Refrigeration S
#1 robalayon
robalayon
  • 4 posts
Posted 16 April 2014 - 09:31 AM
Hi everyone. I've to do an investigation project of methane liquefaction.
I propose do this using a 3 steps-cascade refrigeration system, and the refrigerants are Propane, Ethylane and Nitrogene. When I do the first step of the refrigeration system with Propane, and I simalute it in ProII,  it gives to me an irregular behavior, because when i put in the evaporator (2cell HX), i get that in the entrace of the compresor I have a mix of the refrigerant, besides the cold line in the 2cell HX, is doing the process with a constante temperature. That does have any sense.
So, does anyone know why I'm getting this? Your help will be useful.
PD: Sorry if I have any writing error.
#2 Bobby Strain
Posted 16 April 2014 - 04:32 PM
You only need to specify that the refrigerant vapor from the exchanger is 1.0 fraction vapor. Don't use a temperature spec.
