Dear all,
I will need all the help I can get. I am be assigned to design a salt water disposal plant. My requests are as follow
1- if you have anything that can help with the oil-water separation (spreadsheet ,publications etc...) unit please share
2- how much control do I need? (For some of you who have designed this before)
All I have so far are the API , flow and temperature into the oil water separator.
2-can you share any knowledge you have about desanders?
I am at a very initial phase and trying to understand the assignment itself . Once I crank some number I will share for your inputs.
Any help will be appreciated.
Thank you
Salt Water Disposal Plant
Started by Pingue2008, Apr 19 2014 07:36 PM
No replies to this topic
Posted 19 April 2014 - 07:36 PM
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Rapid Depressurization Of WaterStarted by Guest_golegolegole_* , 31 Mar 2024 |
Sulfuric Acid PlantStarted by Guest_Kartik54_* , 16 Mar 2024 |
Water Seal Pot Of Prv Working PrincipleStarted by Guest_panagiotis_* , 23 Feb 2024 |
