Cutter Item In Hysys Simulation
#1 Butterfly
Butterfly
  • 81 posts
Posted 23 April 2014 - 03:56 AM
Hello
I am dealing with a hysys simulation (v 7.2) already converged. Fluid package is peng robinson. I wanted to add components, and when I do that and re-enter the simulation, two streams appear with a Cutter after the first two equipments (just after a TEE item).
I was trying to guess what happens, and  I have just noticed that if I enter the Basis environment, Components Tab, click in my Component List (just to see it), and then return to the simulation, the Cutter also appears. Now I'm lost, because I did not make any changes to the simulation.
Maybe somebody has dealed with this problem before, I hope.
#2 aroon
aroon
  • 86 posts
Posted 23 April 2014 - 04:06 AM
Peng-Robinson may not be supporting to newly components. So you might have added another package along with Peng-Robinson with two different basis.
Use of stream cutter is to export stream from one Thermo-package to another. Hope this may be resolve your issue.
#3 Butterfly
Butterfly
  • 81 posts
Posted 23 April 2014 - 07:31 AM
Thanks, that was the problem. Some streams were changed to other property packages.
Changing the packaged again to the original one has removed the cutter.
