Hi all,
Please see attached file for your understanding.
This is a about 100% oversized naphtha heater. Naphtha is on tube side and 50# steam is on shell side. Naphtha outlet temperature is controlled by adjusting the liquid level inside the heat exchanger. Since the heat exchanger is greatly oversized, only controlling the condensate level can not meet the requirement for naphtha outlet temperature control and steam inlet block valve is used for throttling steam as well.
Since the heater was installed, Water hammering has been observed inside the heat exchanger. Operators opened the drain valve to sewer the condensate to eliminate the water hammer. It seems to me that the system has difficulty to get the condensate back to condensate drum mainly due to low pressure inside the heat exchanger (high pressure drop through the stream inlet gate valve). Another reason may be the interference of condensate control valve and steam trap or pressure drop through the steam trap.
My questions is:
Is the steam trap down stream of the control valve necessary or the steam trap can be removed?
Thanks advance for your comments.
