HI,
What should be the required flowrate of a PSV (pop-up) for natural gas regulating and metering station (RMS)? Is it 5% of the inlet flowrate of an equipment? Any standard or reference?
Posted 25 May 2014 - 11:17 PM
HI,
Posted 26 May 2014 - 12:33 AM
No specific standard, just system analysis and identifying credible overpressure scenarios and then specifying governing scenario with relevant required relief load...
Posted 29 May 2014 - 06:41 AM
Dear Fallah,
Thanks for your comments.
Posted 22 September 2014 - 02:31 AM
Hi fallah,
Would appreciate if you comment.
In IS 15729: NATURAL GAS PRESSURE REGULATING AND METERING TERMINAL CODE OF PRACTICE
https://law.resource....15729.2007.pdf
"The capacity of pressure-relief valves and vents should be designed to limit pressure in the system to the extent which may as specified for various sub-systems. The relief valve be capable to pass maximum one percent of the effective full stream flow at full fault condition. working life."
Thank you
Posted 22 September 2014 - 03:12 AM
It's a local standard and if it is the standard by which your are designing the NG regulating and metering system, you should follow such criteria for specifying the relevant PSV capacity...
Assigning Feed Flowrate In Dynamics Mode In HysysStarted by Guest_Estiqaatsi_* , 28 Nov 2022 |
High Pressure Drop Across Liquid Pipeline At Minimum Flowrate Case . VStarted by Guest_hariz-process_* , 03 Jun 2021 |
Crude Carrier Unloading StationStarted by Guest_sargon 1979_* , 20 May 2021 |
Different Flowrate In Top And Bottom Of RadfracStarted by Guest_r_hothi_* , 17 Jul 2020 |
Mass Flowrate Of Steam TurbineStarted by Guest_Noay_* , 17 Mar 2020 |
