Dear all
I have some questions when studying SCOT process. In the process, why the gas after scot reactor is contained CO2, and why we have to selectively absorb H2S, it's OK if the alkanolamine also absorb CO2 ?
Thank in advanced !
Posted 17 June 2014 - 09:31 AM
Dear all
Thank in advanced !
Posted 17 June 2014 - 11:03 AM
There is a lot more to this question.
The "scot" reactor is a hydrogenation reactor, meant to convert and remaining Sulfur compounds back to H2S. However, the stream will still be ~90% N2, H2O and CO2. You want to get rid of as much of the inerts (including CO2) as possible, but recycle your H2S back to the beginning of the SRU. The purpose is to have a greater total sulfur recovery (~99.98%).
Posted 17 June 2014 - 11:56 AM
Thanks RockDock
Is your point: CO2 has to be removed to the SRU has effective recovery (Sorry! English's not my native, so cannot totally understand your reply)?. But I think if the fed contains CO2, the SRU is still fine ?
Posted 17 June 2014 - 12:10 PM
No problem. I think I had a typo or two in there, too.
CO2 does not hurt the process, per se. In fact, you will be producing CO2 through the combustion chamber, anyways. The trouble is that the higher the concentration of H2S in the inlet to the SRU, the easier it will be to operate the SRU. Since there is no reason to have the CO2 being recycled back to the SRU, it just makes sense to use MDEA to selectively recycle the H2S and let the CO2 slip to the incinerator. The more CO2 in the acid gas, the lower the concentration of H2S.
CO2 is more or less inert. Ideally, you want the feed to the SRU to be about 40-60% H2S. Below that and you will need to modify the design and probably spend additional money for various enrichment technology.
Posted 17 June 2014 - 12:40 PM
Thank sir
It very useful and helpful. Now, it's very clearly to me
Posted 17 June 2014 - 03:01 PM
Rock,
I think that a SCOT, (Shell Claus Offgas Treater), unit is nothing more than an amine absorber and stripper to remove H2S from the Claus unit offgas and return it to the Claus unit feed. This allows sulfur recovery to approach 100%. I didn't know that a hydrogenation reactor is also included. But now I know about the hydrogenation step. Thanks.
Edited by Bobby Strain, 17 June 2014 - 04:44 PM.
Posted 18 June 2014 - 12:50 PM
Glad I can help!
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Let Down Vessel In Methanol ProcessStarted by Guest_Manue_* , 21 Mar 2024 |
Electrical Inputs From ProcessStarted by Guest_Chari_* , 06 Feb 2024 |
Recycling Of Working Solution In The Anthraquinone ProcessStarted by Guest_Has2riasat_* , 01 Feb 2024 |
