what are manually opearated valves, are manually operated valves are different than ball valve in the oil and gas industry? please explain.
Manually Operated Valve
Started by krishnamurthy, Jun 20 2014 11:11 PM
Posted 20 June 2014 - 11:11 PM
Posted 20 June 2014 - 11:53 PM
Dear :
Manually operated valve may be ball valve and other types such as globe,gate and so on.
Best
M.R.Rahimzadeh
Posted 23 June 2014 - 01:41 PM
Manually operated valves typically have a lever or wheel that is turned by hand to open or close the valve. The operator locates himself next to the valve to operate it. "Manual operated" describes the actuator only -- the valve is not part of any automatic control.
Wafer Check ValveStarted by Guest_Ali4269278331_* , Yesterday, 01:31 PM |
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Valve Cv InputsStarted by Guest_QuantumEng_* , 01 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
Self Actuated Pressure Reducing ValveStarted by Guest_panagiotis_* , 16 Feb 2024 |
