Help me please,How do I check the performance of liquid ring vacuum pump?
I attached the expected curve from supplier under this comment.Thank you very much
Liquid Ring Vacuum Pump Performance Check
Started by Micky mouse, Jun 25 2014 08:32 PM
Posted 25 June 2014 - 08:32 PM
Posted 29 June 2014 - 07:59 PM
Micky mouse,
May I know which vendor gave you such a cryptic performance curve?
I would call it an introductory sketch, not an expected performance curve for your vacuum pump.
Give us some numbers to comment.
Top curve is Volumetric flow (left y-axis) vs Vacuum pressure (x-axis), bottom curve is Horsepower (right y-axis) vs Vacuum pressure (x-axis).
xavio
Posted 30 June 2014 - 03:22 AM
Micky mouse ,
A technical document from a reputable supplier to support your work .
Good luck,
Edited by breizh, 30 June 2014 - 03:24 AM.
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Answered
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Answered
Vacuum Ejector Pressure ControlStarted by Guest_himanshu.ch_* , 19 Mar 2024 |
Vacuum DistillationStarted by Guest_hysyshunter_* , 12 Mar 2024 |
