Hi everyone!
I need your help in this. It is a problem from our ChE Licensure exam.
A 1-m inside diameter spherical tank is 75% full of liquid benzene at 25 oC. The cap of the 70-mm diameter opening at the top of the tank was not put in place by mistake causing a benzene vapor loss through the opening. Calculate the rate of loss of benzene by molecular diffusion if the pseudo-state condition is assumed to apply. The temperature is at 25 oC and the pressure is 1 atm. The cap is very short and the diffusion through the open space within the vessel needs only to be considered. The vapor pressure of benzene at 25 oC is 0.127 bar.
