Dear all,
I want to compare the pressure drop in the well but using using LBC correlation and using Hysys. From the reservoir simulator the pressure is calculated using the LBC equation for viscosity, but I do not have LBC model in Hysys . On the contrary hysys uses Viscosity index(I think) with coefficients A and B which we can play with.
How can I get the same value of pressure drop when I have to two different models for viscosity calculation?
Sacarove
