Dear sir,
What is Langelier saturation index and Ryznar stability index? What is the importance of it?
Kindly give some inputs. Thank you
Posted 08 July 2014 - 09:43 AM
Dear sir,
Posted 08 July 2014 - 07:43 PM
Google will support this type of query ! Basically it will indicate the ability for species to precipitate and generate scale in your system (piping , HX , Cooling tower ) .
Ryznar index is similar , both could be used to evaluate the quality of water .
http://www.lenntech....x/langelier.htm
Edited by breizh, 08 July 2014 - 11:18 PM.
Posted 11 July 2014 - 10:11 AM
Dear Breizh
In our cooling water system the chloride concentration is around 700 ppm will it have any corrosion effect in the Heat exchangers?
Posted 11 July 2014 - 06:17 PM
HI ,
700 ppm seems a lot !
I would advise you to contact the company in charge of supplying chemicals for your cooling water system and ask them to perform an audit .
Corrosion can develop very quickly .
My 2 cents
Posted 12 July 2014 - 12:40 AM
sarathkumar,
Corrosion effect of 700 ppm chloride depends on the material of the heat exchanger. If it would be from Titanium or Duplex, almost no corrosion effect otherwise corrosion mostly in the form of pitting would be encountered...
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Rapid Depressurization Of WaterStarted by Guest_golegolegole_* , 31 Mar 2024 |
Water Seal Pot Of Prv Working PrincipleStarted by Guest_panagiotis_* , 23 Feb 2024 |
Remove Water From Ammonia Aspen PlusStarted by Guest_fmalik_* , 12 Feb 2024 |
