Distillation
Posted 15 July 2014 - 10:36 AM
Posted 15 July 2014 - 11:16 AM
None of us know what you are talking about. Maybe you can pose your query without using acronyms. And we have no idea what a simmering column is.
Posted 15 July 2014 - 12:14 PM
Consider that the pressure at the bottom of the column is higher than the pressure at the top of the column because the liquid in the column adds to the pressure. Recalculate your boiling point temperature at the higher pressure to check your composition.
Edited by Pilesar, 15 July 2014 - 12:16 PM.
Posted 15 July 2014 - 12:46 PM
our product ENA which is 68 % proofDo you mean 68 proof, which is 34 vol%? Or do you mean 68 vol% (136 proof)?
Boiling point of pure ethanol is 78 oC, but boiling point of 34 vol% or 68 vol% ethanol is higher due to its water content.
Reactive Distillation MtbeStarted by Guest_Michael Mitra_* , 15 Mar 2024 |
Vacuum DistillationStarted by Guest_hysyshunter_* , 12 Mar 2024 |
Distillation Column DiameterStarted by Guest_refluxraider_* , 12 Mar 2024 |
DistillationStarted by Guest_refluxraider_* , 13 Mar 2024 |
Diameters Of A Structured Packing Distillation Column With No VapourStarted by Guest_hysyshunter_* , 07 Mar 2024 |
