Hi.
The attached sketch I have HDPE pipe 10 "diameter, carrying water. The pipeline works 60% of the section. Height difference between the tank and the point B is 160m. (see sketch)
Is required to know if there is a market in energy dissipation device which is connected to the discharge pipe (point B in the sketch) to dissipate energy due to water leakage rate not to undermine the ground.
Not build a concrete energy dissipator in the area.
The data is in the attached sketch
