I am performing a calculation to size the flow rate through a small packed column to atmosphere (scrubber). The upstream flow rate is a maximum 500 Pascal (discharge pressure of purge fan) , according to the laws for choked flow of ideal gas, critical pressure ratio of air is around 0.528. If i do the quick calculation based on my upstream pressure I get 260 Pa as my downstream critical pressure.
Sure for such low pressure air cannot reach sonic velocity???
Appreciate your knowledge
