Dears,
I have come across situation, wherein I am required to explore various scenarios for calculating PSV capacity for vessel that is operating under vacuum.
Apart from fire case, I have learned that ejector motive fluid (steam) may get entrained into process side, if the steam pressure drops below its “pick-up” pressure. In that case, this could be additional scenario.
Please suggest if such scenario is credible one & in that case, the procedure to estimate PSV capacity for the same.
Thanks & Regards
