Operation Of Day Tank (Filling And Emptying)
Posted 03 August 2014 - 04:55 PM
Posted 04 August 2014 - 08:31 AM
Pingue2008
How are you communicating to this forum? By texting with a cell phone? Your post is terrible and difficult to read and understand in one sitting. I have edited your post to read as follows:
"All,
I have been assigned to design a fairly simple system but I am running into some issues.
First, I am unloading CHDM from an ISO Container to a tank.
The control on the transfer pump (pump that pumps CHDM to the tank) is on/off. The transfer pump will be pumping at 8 gpm and the flow out the day tank is 3 gpm. Once the ISO container is empty I switch and put in another one. The ISO container capacity is 10 times the day tank capacity.
I am thinking of ways to operate this system. My idea is:
1. Whenever the day tank is 80% full, turn off the transfer pump. Let the day tank run down to 50% full and turn on the transfer pump.
2. Do these steps until the ISO container is empty.
This idea does not sound right. Turning this pump off and on is kind of scary.
My question to you is: Do you have a better way of doing this?
I was thinking that if the company can pay for a VFD motor drive on the transfer pump, i could fill the day tank to 80% and reduce the transfer pump rate to match the outlet flow rate of the day tank. By doing this I could achieve a steady state until the time came to switch the iso container. The time to switch the ISO container is about 2 hr and during this time the level in the day tank will drop to around 40%. Repeat this again and again. Your comments will be appreciated.
Thank you"
Is that what you mean to write? Perhaps our members can understand this version quicker and more accurately.
Posted 05 August 2014 - 09:35 AM
Does CHDM = cyclohexanedimethanol? If so, you probably are using some sort of heat source to prevent freezing. Also, what kind of pump is being used? I would not be particularly concerned with starting/stopping a most small pumps every couple hours, unless there are specific process related issues. Without these specifics, but making my best guess, I would consider two alternative options:
1.) Use nitrogen to pressure material from ISO to process. On-off control of a shut-off valve would be probably be sufficient (but you could also use a continuous control with a globe valve).
a.) Nitrogen pressure will need to be greater than the process pressure
b.) ISO will need to be rated for said pressure, with proper relief system
c.) facilities will need to be available for depressuring the ISO when empty
2.) Recirculate the pump discharge to the ISO through an orifice and level control to the day tank using a globe valve (preferably automated)
a.) pump would run continuously except when switching ISOs
b.) heat generation from the pump is not likely a concern if you are heating the material anyway
c.) may not be a viable solution depending on the style of pump
If you are using an on-off scheme you need to consider the question: "what happens if the ISO goes empty shortly after turning on?". For instance, if you are controlling the level between 50% and 80%, the worst case would result in a minimum level of 10%. Does this leave provide necessary risk mitigation? What is the cost of losing feed, etc. Using a VFD is not a bad idea, but the correct choice depends on the specifics of the process. I hope I have given you a couple of alternative ideas.
Posted 06 August 2014 - 06:10 PM
Thank you all,
I will upload a BFD later.
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Asme Code For Fiberglass Pressure Tank FeaStarted by Guest_Pheeto_* , 13 Feb 2024 |
Pressurized Deaerator Tank Exhaust Vent SizingStarted by Guest_zezima_* , 01 Feb 2024 |
Operation Of Heat Exchanger Above The Overall Heat Transfer CoefficienStarted by Guest_Papps_* , 13 Jan 2024 |
