Hello..
I'm power system engineer.
First of Heat balance calculation, I have experience setting initial condition of steam turbine without any reference.
In case of waste to energy, steam rate is just 30~80 ton/hr because of low NCV considering boiler size.
As you know, inlet pressure and temperature maximizing, system efficiency maximizing. And every owner prefer to high system efficiency because of low fuel consumption.
Is there any method to set the upper limit of inlet pressure and temperature without any reference during proposal stage?
If there's no method, This will be my last question as power engineer...
