Cracking Gasoline Vapor?
Posted 13 August 2014 - 09:36 PM
Posted 14 December 2014 - 01:27 AM
Light molecules of hydrocarbons do not crack. Gasoline contains hydrocarbon molecules of C5 to C10 range. Hydrocarbon molecules of C30+ only crack which are present in vacuum gas oil and above.
Posted 14 December 2014 - 06:15 AM
49lone82,
Gasoline is Naphtha range molecules. Steam crackers crack Naptha routinely to produce Ethylene.
Typical temperature in Naphtha cracker furnaces outlet is 800 deg C for significant yield, but cracking starts at around 400 deg C.
Sufficient information exists on reaction kinetics and mechanism of steam cracking of Naphtha for you to study your system.
Sachin
Posted 14 December 2014 - 07:33 AM
Yes. Gasoline cracks only under some conditions, like catalysts, steam . It does not crack under normal conditions. Your first question gives the impression that you want to crack gasoline vapor to use it in the vehicle.
Vapor PressureStarted by Guest_Hamza1111_* , 23 Mar 2024 |
Vapor Balance Line From Pump Cane VentsStarted by Guest_100RB_* , 03 Jan 2024 |
Equilibrium Vapor Liquid Solid In Trickle Bed ReactorStarted by Guest_nannanine_* , 14 Dec 2023 |
Subcooling And Vapor Refrigerant CondensationStarted by Guest_panagiotis_* , 19 Nov 2023 |
Bulk Residence Time In Naphtha CrackingStarted by Guest_mehul_* , 19 Oct 2018 |
