Modelling Of Fitting (Tee) In Flarenet
No replies to this topic
#1 arvind
arvind
  • 61 posts
Posted 23 August 2014 - 02:10 AM
I want to model a tee connection flarenet.
I have already provided upstream, downstream and branch connections to Tee section.
I want to know to model pressure drop in Tee, I still have to add following fittings?
a). In upstream pipe - fitting as Tee standard flow through run.
B). In branch pipe - fitting as Tee standard flow through branch
As Tee is already defined in model? is it still required to model above fittings or it will automatically get covered?
