Vent Line Sizing
vent line mach number limitation
#1 ist10
ist10
  • 7 posts
Posted 27 August 2014 - 03:04 AM
Dear all,
we are about to define process specifications for a silencer on a vent line. The system pressure is as high as 35 barg and the vent line is open to atmosphere. For a given pipe size with adiabatic compressible flow, we are reaching Mach Number = 1.0 without losing half the pressure of 35 barg as the friction loss on vent line. I am aware that it is not possible to go beyond  Mach=1.0. There will be some allowable pressure drop for the silencer itself but I don't foresee this wll be great. Therefore the excess pressure will be lost at the pipe exit due to sudden expansion but I assume that this is not something allowable. Can somebody shed some light on that?
Many thanks
Kind regards
#2 fallah
  • 4,951 posts
Posted 27 August 2014 - 03:15 AM
ist10,
Is the vent line a PSV discharge line? Can you upload a simple sketch of the vent system?
#3 ist10
ist10
  • 7 posts
Posted 27 August 2014 - 03:24 AM
Fallah,
not a PSV discharge line. The main line is gas supply line to gas turbine and the vent is intended to discharge the volume within two valves in case both closed.
#4 fallah
  • 4,951 posts
Posted 27 August 2014 - 03:47 AM
ist10,
Yes, the excess pressure will be lost at the pipe exit due to sudden expansion along with the shock waves and noise; and the silencer is located there (pipe exit) to silence the noise to an acceptable level permitted by local regulations...
#5 ist10
ist10
  • 7 posts
Posted 27 August 2014 - 03:51 AM
Fallah,
many thanks for the response. I can imagine the noise limitation will be solved via silencer; however do you think that this shock wave created by the sudden expansion is allowed in terms of say pipe supports and so on?
#6 fallah
  • 4,951 posts
Posted 27 August 2014 - 04:32 AM
ist10,
The created shock waves and vibration should be damped by proper pipe supporting system...
