I am doing school project using distillation column.
Control programs will be three including delta v.
Our high temperature will be 100.
What type insulation material do i need to use for it?
Edited by hiseana, 29 August 2014 - 04:23 PM.
Posted 29 August 2014 - 04:19 PM
Posted 29 August 2014 - 08:10 PM
100 what? oF oC oR oK ?
What are the chemicals being seperated?
What is the material of construction of the distillation column?
Is column inside or outside?
What is the climate and extremes?
What are dimensions of column?
Diked Area Around Distillation ColumnStarted by Guest_hysyshunter_* , 15 Apr 2024 |
Distillation Column Decommissioning ChecklistStarted by Guest_m.bhut_* , 08 Apr 2024 |
Reactive Distillation MtbeStarted by Guest_Michael Mitra_* , 15 Mar 2024 |
Vacuum DistillationStarted by Guest_hysyshunter_* , 12 Mar 2024 |
Distillation Column DiameterStarted by Guest_refluxraider_* , 12 Mar 2024 |
