Three Stage Process, Material Balance
material balance threestageprocess
7 replies to this topic
#1 naverrak
naverrak
  • 14 posts
Posted 01 September 2014 - 12:42 AM
Hi, for this question I have done questions i) and some of ii) but I am stuck for the rest.
i)
let U=unknowns
     E=equations
stage 1:
no. of unknowns=5
no. of equations=4
U>E
 therefore this is not solvable
stage 2:
no. of unknowns=5
no. of equations=4
U>E
stage 3:
no. of unknowns =3
no. of equations =3
U=E
therefore stage 3 is solvable.
ii)
P3/D3=3
D3=10lb (given)
therefore P3=30lb
ratio A:B in P2 is 4:1
therefore P2 has composition 0.8A, 0.2B
Here is where I am stuck, I cannot solve for the other unknowns.
The final answers that were given are: D1=30lb, D2=30, P2=30, P3=30, E=10 and stream E consists of 59% A and 41% B.
  • 6,334 posts
Posted 01 September 2014 - 02:09 AM
Naverrak ,
Should not be difficult . Just apply in= out for both ( global and individual A,B,C) , write the equations . As suggested many times by Art , you can use an excel sheet to perform the calculation .
#3 naverrak
naverrak
  • 14 posts
Posted 01 September 2014 - 02:55 AM
I'm still confused, for D1, applying in=out
0.5(100lb)=0.5(D1) => D1=100, but the answers says D1=30lb
#4 breizh
  • 6,334 posts
Posted 01 September 2014 - 03:07 AM
No !
You need to perform the balance (total) >>> 1 equation + perform the balance on C solve 2 equations with 2 unknowns !
#5 naverrak
naverrak
  • 14 posts
Posted 01 September 2014 - 03:40 AM
I am honestly still confused, could you show me the first step?.
#6 breizh
  • 6,334 posts
Posted 01 September 2014 - 03:51 AM
Global
D1+D2+ D3+P3= F  >> D1+D2 =60 with D3=10 and P3=3*D3
balance on C  30= 0.27 *D1+0.73*D2
All the answers are correct !
Edited by breizh, 01 September 2014 - 04:54 AM.
#7 naverrak
naverrak
  • 14 posts
Posted 01 September 2014 - 08:25 AM
Hi, to get E, I did
E+P2=D3+P3
If i use a mass balance:
E+(0.8)(30) = 10+(0.7)(30)
E=7
but this is obviously wrong since you said all the values were correct.
however if I do
E+P2=D3+P3
E+30=10+30
E=10.
How are the values different when the method used should get the same feed value for E (I think).
Also for the composition of E, I have to find P2 right?
using box 2 as a control volume:
mass balance A:
p1 has mass 100-30-10       (from D1 and E)
=60lb
P1=D2+P2
60A=0.17(30)+0.8(30)
A=0.485
therefore B=0.515
mass balance for Box 1:
F=D1+P1+E
using A as a component
0.5(100)=0.5(30)+0.485(60)+10A
A=0.59
therefore B=0.41
Did I use the correct method (even though answers were right)
Edited by naverrak, 01 September 2014 - 08:50 AM.
#8 breizh
  • 6,334 posts
Posted 02 September 2014 - 08:06 AM   Best Answer
Naverrak  ,
You should follow what Art and I have explained to you , use an excelsheet like the one I uploaded.
To me this kind of homework is really great fun.
In red calculation , in black data (known)
With a table you can crosscheck easily your mass balance ( key point) .
Good luck !
Edited by breizh, 02 September 2014 - 08:07 AM.
