Pump Fundamentals
Started by snmansuri, Sep 08 2014 09:47 AM
Posted 08 September 2014 - 09:47 AM
What will be the effect on pump flow and head if we trim the impeller in centrifugal pump
Posted 08 September 2014 - 09:52 AM
Consider to check the pump's curves , you will get your answer . Curves are provided for different impeller at RPM =cte
Note : Google "Affinity laws Centrifugal pump " or use the search engine in this forum , you will get more info .
http://www.webbpump....pport/index.php
Hope this helps.
Edited by breizh, 09 September 2014 - 02:59 AM.
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Piping Design_ Pump PipelineStarted by Guest_anh.phungthai@boydensvn_* , 29 Feb 2024 |
Design Considerations For Cryogenic Submersible PumpStarted by Guest_heydari_* , 04 Feb 2024 |
Variable Speed Pump CurvesStarted by Guest_panagiotis_* , 27 Jan 2024 |
