Dear members,
Chilled water flow of 1500 m3/hr is required for the sustenance of the present system at our Plant . An insulated closed tank of capacity 150 m3 with supply pumps (5 nos., 3 running, 2 stand-by) was designed for the mentioned purpose, having a total discharge head of 55 m and capacity of 555 m3/hr each. With recent modifications in the plant, a separate cold well with supply pumps (55 m head, 5 nos., 3 running, 2 stand-by) to process units were established in the plant premises. These changes reduce the required head on the hot well supply pump to around 30 m, as it traverses only up to the cold well via the ammonia chiller system. Now instead of two pumps we are operating only two pumps, because of head reduction the flow got increased. The present power consumption is 220 KW. I don't have the pump performance curve, it is a old pump with the serial number i asked the vendor to provide, but they couldn't find it. My question is whether my pumps are running with lower efficiency? if i replace the pumps with required head will i have any power saving? awaiting for your replies.thanks in advance.
New Microsoft Office Excel Worksheet.xlsx 12.42KB 24 downloads
