Hey guys
I have a hydrocarbon vapour at a high temperature during a fire in a tank.
I have calculated the mass / actual vol flow of this vapour.
PVV / Vent catalogue is based on STD flow of air.
How do you calculate the standard flow of HC vapour if at standard conditions (60F / 0 barg) liquid drops out of the vapour phase? (It doesn't follow ideal gas law as liquid will drop out at a certain temperature)
Could I convert the standard air flow value from the catalogue to actual volume flows at the relieving T and P and work on an actual volume flow basis?
