Hey Guys
To convert a standard flow of a vapour to an equivalent flow of air can I use the following equation?
Equivalent STD flow of air = STD flow of vapour x ( Molecular weight vapour / molecular weight air)
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Coefficient Of Conversion Of Electrical Energy Into Thermal Energy ForStarted by Guest_amx_* , 03 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
