Polytropic Head & Effciency Calculations
9 replies to this topic
#1 Said Salim
Said Salim
  • 96 posts
Posted 18 September 2014 - 12:15 AM
Dear Members,
A four stages CO2 compressor datasheet is attached. However, I am having a doubt in the datasheet
calculations of both polytropic head and efficiency if I used datasheet values of compressibility factor (z) and
specific heat ratio (k) to calculate polytropic head and efficiency respectively the will not give the same as what
stated in the datasheet and hence the power consumption will be different. My question wether I have calculated
them wrongly or the supplier is using a different  method of calculations other than what I am using.?
I have attached my calculations along with datasheet. I will appreciate your response.
#2 Bobby Strain
Posted 18 September 2014 - 11:41 AM
You should use a process simulator to check the calculation. Average properties are not suffiently accurate for CO2 compression.
#3 himant
himant
  • 53 posts
Posted 18 September 2014 - 11:30 PM
as per excel sheet, calculations look fine to me...
but what's with varying molecular weight, mass flow rate, etc?
and i hope it doesn't have anything to do with "Difference between Operating point & Surge"
Himant
#4 breizh
  • 6,346 posts
Posted 19 September 2014 - 03:28 AM
said ,
I confirm the data sheet values for Z , using Redlich & Kwong model , except for the suction 4 stage ( Z1= 0.6124 )  .To me there is a typo on the data sheet , Zs and Zd are different.
For Polytropic head , Z value @ suction should be used (refer to relation attached with your table) , not the average value.
Hope this helps
Edited by breizh, 19 September 2014 - 04:48 AM.
#5 PingPong
PingPong
  • 1,446 posts
Posted 19 September 2014 - 05:28 AM
Breizh is correct that 4th stage Z on datasheet is too high.
Using the NIST webbook for pure CO2 one would find for 4th stage that Zin = 0.563 and Zout = 0.672 @ 110 oC (so average Z = 0.618) and the enthalpy increase is 48.9 kJ/kg.
For a flowrate of 81032 kg/h (22.5 kg/s) that gives a 4th stage gas power of 1100 kW. Add 20 kW for mechanical losses and one gets 1120 kW.
When using the standard textbook formula to calculate Head and Power one should not recalculate the polytropic efficiency from T2/T1 but use the vendor efficiency. In that case the calculated powers and polytropic heads would be much closer to the vendor data than Said calculated. But for the 4th stage one should then of course also use the correct value for Z.
Edited by PingPong, 19 September 2014 - 05:50 AM.
#6 himant
himant
  • 53 posts
Posted 19 September 2014 - 05:34 AM
can you please tell me what's with varying flowrate and varying molecular weight? I am confused!
Is it part of refrigeration cycle?
regards
himant
#7 Said Salim
Said Salim
  • 96 posts
Posted 20 September 2014 - 11:20 PM
 Dear PingPong,
You meant to say that the vendor has determined the polytropic efficiency practically not by the normal calculation procedures.?
Said Salim
#8 Said Salim
Said Salim
  • 96 posts
Posted 20 September 2014 - 11:35 PM
regards
himant
Dear himant,
It is not a part of a refrigeration cycle. It is a CO2 feed to a urea reactor. However, variying of Molecular weight and flow is due to the addition of passivation air in the 1st satge discharge and taking into consideration the removal of moisture in interstage seperators.
Said Salim
#9 Said Salim
Said Salim
  • 96 posts
Posted 20 September 2014 - 11:56 PM
Dear Members,
Thank you all of your response I have checked the 4th stage values of Z and k as well using both HYSYS and NIST webbook and they were different than what is available in datasheet. Actually, I used to consider whatever given by a vendor datasheet is accurate and no way to have such typo mistakes.
Said Salim
#10 PingPong
PingPong
  • 1,446 posts
Posted 21 September 2014 - 04:39 AM
I am sure that the vendor simply copied the values for Z and k from the purchase order of the buyer, but did not use them as the vendor used their own software to calculate Discharge Temperature, Head and Power.
Vendor calculates (or better: predicts) discharge temperature using known polytropic efficiency, not the other way around.
If you like to calculate something back from T2/T1 then you could calculate (n-1)/n and use that calculated term in the rest of the formula for Hp. Or even better: use vendor value for Hp to calculate back (n-1)/n value.
Note also that stage 4 works in the dense phase area of CO2 where properties change differently with changes in P and T.
